Rectifier wiring - Help Please!
Erskine
Over 1,000 Posts
Having rewired my bike successfully to ignition only :) :)
I now want to have the option to run basic lights and stop light and horn. I'm thinking of re instating the regulator/rectifier with a capacitor in place of the battery and I'm trying to work out the wiring for the regulator.
Below is the original wiring diagram from the bike which has all been binned.
The regulator has 5 wires yellow white green red and black.
Yellow and white come from the generator.
Green is the earth.
Red goes to the battery ...........
But what do I do with the black one?
It goes to the ignition switch where it gets bridged to the red, it also used to light up a meter on the cluster.
Do I just join it up to the red to complete the circuit?
I think it may be a load sensing wire?
I am an electrical ignoramus so go easy on me. :o
It's using Honda colours, your right, it's a sensing wire
black goes to a switched battery voltage live feed.
It's voltage dependant not load dependant, should cut off around 14v for a 12v system
