Refurbishing rubber?
sl8rxlr8r
Buy the ticket, take the ride.
So... I have some bits for the bike that are OLD rubber, and hard now. (like the rubber bushings that my handlebar clamps slide through on my triple trees)
Is there anything that can be done to help make them a little more soft and pliable? I was thinking about maybe trying to soak them in olive oil or something? Anybody know any tricks?
Thanks
Soaking in a cup of green antifreeze will soften the outer part up but if they are hardened all the way thru chuck'm and replace.
Thanks
Here are some products that will do the trick.
1. BMW Gummifledge (Rubber Care) probably the best product out there, however it's no longer made by BMW.
2. Wurth Gummifledge you can buy this at a VW or Audi dealer
3. Zymol Rubber Care
4. Einzett Rubber Care
5. 303 Aerospace
6. GM Rubber Care (only available in Canada) GM dealer
7. Glycerin local pharmacy
8. Carb cleaner the one that comes in a 1 gallon can
Hope this helps, I am not an expert but I have a collection of these products.
if you have a problem finding anything new talk to clause at (i think) claussestudios.com (if it doesn't work just search for clause studios vespa and you should find it)
he does 1 off sand cast plastic/rubber stuff for pretty reasonable prices. he specializes in vintage scooter work but if you want a custom taillight lens or solid hens-tooth bushing he can do it.
There are extensive discussions over at SOHC on trying to refurbish old hard rubber. I have tried many of them with disappointing results. Buy NEW was the best advise but if your bent on using what you have, I found a heat gun to be the easiest remedy. Sure, the rubber returns to the rock hard state but if I got everything put back together and clamped whilst it was still warm everything was ok again.
Boiling????????okay!! slightly off the topic,a wiring harness,can be soaked in laquer thinner to make to more pliable,,,auto restorer trick,,,,,,,,,,can't find the nos rubber,,,replace it with teflon!!!!!!!!!,,,,,,,,,,good rubber luck!!!
Yeah boiling them. Often read about people boiling thier intake boots to make them plyable again, most with great success. Some, however, simply needed to replace them, as there was no saving them in the first place.
There are several threads on this topic on other sites (SOHC.com et al). Many recommend boiling rubber parts in wintergreen oil (Methyl salicylate) and water. I tried wintergreen oil for the first time last night and the results are very, very good. There is a commercial product called "Rubber Renue" which according to the MSDS is nothing more than Methyl salicylate and xylene. So I mixed up both and soaked (no boil) rock hard carb intake boots from a CB750 in a mason jar overnight. I gently heated them first with a heat gun to open up the rubber. They are now soft and pliable. I have not run them yet so I cannot say if there are any vacuum leaks.
I soaked a rock hard carb boot in Armor All for 7 days and it did nothing.
Wintergreen oil is available online or at most drugstores, pharmacies and /or coops as a analgesic and liniment for sore muscles. Smells like Pepto Bismal.
This sounds interesting. Please tell us what the results were of your experiment after the rubber part/s were cooled off. Did they remain soft or at least pliable?...or did they return to the origional hard state?
I am happy to report a mixture of wintergreen oil and xylene works very well for revitalizing old, hard rubber.
After soaking a rock hard CB750 carb boot overnight it it came out soft and pliable. It has been out for 24 hours and it is still soft and seats and seals well onto its carb. I had a cb400 carb boot in all day and it came out beautiful too. Now I have several soaking. For each I only used a heat gun for 30 seconds just to warm them out before putting them into solution at room temperature, no addition heat or boiling.
I have four CB cafe projects going at the moment and I would rather try to revitalize and reuse their rubber products if possible. Each bike ran before I stripped them down. If any do not work after treatment, then I will invest in new rubber pieces.
So far this sounds very interesting. I would like to try it myself. Where can I purchase this commercial product "Rubber Renue" or Methyl salicylate and xylene?
Wintergreen oil (methyl salicylate) is an external analgesic available at pharmacies, health food stores, co-ops et al or online . I paid USD $7.00 for 2 oz. retail.
Xylene is an organic solvent used to clean and thin hard to thin paints and can be found at any hardware or paint store.
Rubber Renue is commercial product containing the two ingredients listed above. I found it online and on E-bay but it is much cheaper to do it yourself.
I mixed 70% xylene with 30% wintergreen oil, gently heated my rubber parts breifly and sealed them in mason jars for 12 hours at room temperature. Amazing. I just pulled some smaller pieces like old, hard side cover grommets after 12 hours and they are extremely soft. Perhaps less time for thinner and smaller parts. My old rock hard CB400f carb boots are now perfect!
I recommend this process, encourage others try it and post their results.
Working in an industry that does finish painting of steel,I borrow small amounts of xylene to clean all my engine parts.I have soaked intake rubbers in this to find that they come out plyable,,,but for how long?? DO not use this for carb o ring gaskets,,,you will be waiting several days for the gasket to shrink to normal...if it's old and baked, buy a new one!!!!
Swan,
You're using about 6oz of mixed product - is that enough in mason jar to submerge the parts? Do they need to be submerged?
Submerged yes. If not, rotate frequently. I did one carb boot at time in a small sealed mason jar.
Good luck and post your results.
