Regulator rectifier help
jinsonphoto
Active Member
So I purchase a Regulator rectifier combo from Dime City Cycles. I opened the box & the wires dont match the instructions. there is supposed to be one black & one white wire that you plug into the black wire & white wire that connected to the original regulator. Instead of the black & white wires there is a green wire & a brown wire.
I have attached a picture of the regulator & the instructions.
If you guys have any thoughts I would be very grateful! I dont want to accidentally fry this new part!
Just in case this happens to anyone else here are the directions:
Take the ESR240 green and attach it to harness white
Attach the ESR240 Brown to harness black
The harness green is ground, it is no longer needed.
-Got this info from member of sohc forums.
