Rejetting a cb400
johnson_steve
Hello this is my first post here though I have been lurking about for the last few months stealing your best ideas for my '78 cb400t. among other modifications the stock air box has been replaced by pod filters and the stock H-pipe with 2 cones will be replaced with a 2 into 1 with a cherry-bomb type glasspack on the brake side. as I understand things this will let more air flow through the engine and lean out the air to fuel ratio and I need to change the jets in the carbs to compensate. right? does anyone know where to get the best deal on a set of jets for this bike? (I have the stock KEIHIN carbs) or have tips on how to tune it properly? I was thinking I could measure the temperature at the exhaust headers to get an idea if either cylinder is lean or rich. does this sound like a good idea? anyone have better ideas?
And though it has nothing to do with this post I'll attach a recent pic of the bike
Hey, sorry I don't have a source for jets, but I just wanted to welcome you to the site!
Great looking bike.
And BTW, can't say the pic has nothing to do with the post... everyone should post a pic of their bike in their first post!
Of course i'll do the obvious thing... and suggest e-bay. But you allready knew that. ;D
Thanks Ease it's further along then that now I took that pic right after I chopped and boxed the frame ( you can see I hadn't even picked up my tools yet.) do all keihin carbs use the same jets? I see lots of jet kits that don't say what keihin carb they are for. is there anyway to know what model carbs I have on this bike?
The only markings on my carbs that I can see are KEI*HIN JAPAN, VB and 21BAPL7 with the A in a little box. I also found a tutorial on how to tune the thing just using a few sets of plugs; which is cheaper then one of those non contact thermometers. is this a good way? do I only need to change the main jets?
HerrDeacon: Z1 looks like a good site plenty of parts for my specific bike but it doesn't list any jets when I look it up by model ('78 cb400tII) it got bookmarked as I know I'll need some of those parts eventually.
Wouldn't be able to tell you if they use the same sized jets... unfortunately I outsourced my carb job. :D
I'm sure someone who has gone through their carbs on here has some info on where to get the specs.
O.K. So I tore my carbs apart made them nice and shiny inside and out there are 2 jets in each carb: a 75 low-speed jet and a 105 main jet. I cleaned these out as they were quite clogged (It did sit with gas in it for about 8 years.) so changing the jets will be quite easy if I can get the right jets. My problem is an overload of information; I googled for information on jetting keihin carbs and found tons of great tutorials that give me information on how it's done and how to tune the carbs but they are all for harley-davidsons which apparently also use keihin cv carbs (though they only have 1) Ironicly the reason I decided to build a honda in the fist place is I live in Milwaukee and all you see around here in the summer are tons and tons of showroom-stock shitty H-Ds.
I really would like the input of someone who has re-jetted one of these hondas and knows where I can get the right jets.
HerrDeacon said:
Z1 Enterprises carries jets. This is where I ordered mine. Great bunch of guys as well.
Boy do I feel dumb after countless hours of googleing mesuring parts of the carb with my digital calipers and googleing some more I find out I have Honda VB series keihin cv carbs and that they use "keihin round main jets" and the cheapest place I could find to get them is Z1 for $2 a pop. :) They didn't show any jets for my bike when I looked it up by model and year, but they have plenty of them if you look it up by catagory and they say they work for "Honda CV/CVK/VB/VD and VE some PD & PE carbs, Kawasaki CV and CVK carbs" I figure I'll get 10 jets: 2 each of 5 sizes but I must put more research into what range in sizes.
also I'm not sure if I should change the low-speed jets? can I just adjust the idle mixture screw or maybe put the old #105 mains in there and adjust the screw?
email siriusconinc.com, they do not list all the jets on there site, but they have in stock
I would #78 or 80 mains and 115 Promary mains
Good luck and thats a nice bike
it has #75 and #105 jets now I ordered from Z1 2 each of the following sizes: #110, #115, #120, #125 and #130 I will probably put the #115 jets in before I put the carbs back on the bike but it looks like they should be simple enough to change with the carbs on the bike if I have to. then all I have to do is weld up the exhaust, finish the rearsets and seat; oh and get the stock cdi ignition to work with my otherwise custom wiring harness and I should be able to take her for a spin. (though not for long as I also need to register it and get a class M licence to be legit.)
