Rejetting, do I need the raise the float height?
djg42
Hello,
I went way up with the main jet, do I then need to also raise my float height? Thanks,
DG
__________________
1980 GS450
I want to say almost definitely - no. But you'll find out if it's starving for gas at higher rpm's.
If you raise the floats too much, it will overflow all the time. Maybe half a mm won't hurt.
I'm with bigR on this one. I wouldn't do it IMO, there should be no way that you'd be pulling in that much fuel that the float couldn't keep up.
It's better to test with just the jets before you start messing with things like the float. One thing at a time when changing you system.
Jay
Sorry guys, you got that wrong.
Raising float height will lower fuel level.
Do 1mm, helps clean up midrange
