AgentX
Over 1,000 Posts
Hi all-
Have an HID light kit to install. Fits into the existing H4 bulb location and should draw power straight from the source, so I'll need to put a relay in the wiring.
What should I be looking for on the relay, type- and spec- wise? Bike has a 180w output alternator with a 12v 5AH battery. It's a 35w HID, low-beam-only setup. (brighter than my current high beam...)
Planning on connecting both the high and low beam leads to the switch terminal (or join the wires before the terminal, if it's cleaner that way given the type of connector to be used). Then connect the power-in lead from the combined battery/regulator-rectifier output, and the power-out lead to the lamp, right?
Anything in particular to watch out for?
