Like this: you can use an adjustable wrench to get a better bite, but rock the lock up and down while pulling it out, you now need a second set of hands or if you have a quick grip clamp use it to clamp the head to the bench
There is a hollow dowel pin in that hole where the wrench is in Tune's pic (I'm assuming you took that bolt out already). You really just have to push/pull the torsion bar out, off of that dowel pin. I used a large flat head screwdriver to push them out from the other end. There is a small gap between the two torsion bars in the middle.
