relocating cb360 exhaust under frame.... modify stock headers?
rustreddesign
So I was playing around with some exhaust ideas today and due to rearset clearance, I think I want to relocate the exhaust under the frame. From what I can tell, if the stock header's vertical section was approx. 1" longer it could clear the front cross brace/motor mount and nestle just inside the frame. Since I will be running rearsets, the rear brake assembly won't be an issue and my 12" shorty mufflers should clear the chain with room to spare.
I guess what I'm getting at is.... Has anyone ever lengthened stock headers? Any advice? It seems like this tubing is thicker walled than autozone type stuff (I measured 1/16" with my calipers). Mcmaster Carr has the correct size tubing but it's only available in 6 foot sections for $43 - ouch. I'm going to be painting and maybe wrapping (if it's really close to the frame) so looks aren't a problem. I'f the thinner walled stuff will work, I'll use it, but if it's better to use the thicker stuff - where can I get it? Having someone fabricate a whole new set is out of the question as I don't have the money to spend and I'd rather do it myself anyway. Are there any threads out there that already touch on this?
Thanks
Stock exhaust is dual skinned which means it has a pipe inside a pipe.
If you can weld get some mandrel bends and fabricate entire thing.
hmmm. I didn't realize that. It looked pretty solid to me, but I'm just looking at the ass end the the unit. I actually just did a google search and found some articles referring to their use of a double wall pipe. If that's the case, why would Honda use a dual wall header. I can think of no reason for it other than maybe heat issues, although those bastards still get hot as hell. I also have some cl360 pipes that have been cut (I guess to remove the mufflers from the ends) and they look like one solid walled pipe. I'm assuming these are constructed in a similar method to the cb360s. could it be that the dual wall was used at the beginning of the headers, going to a single wall at the end of the pipe? Any cross section pics out there? I would be interested to see one just for shits. I couldn't find any cross section pics during my quick google search. Nothing can be easy.
If you look through Crazy PJ's build (don't remember which one - probably the 360) he actually made a custom welded exhaust. That's all the info I have.....
Front pipes are double skinned to keep chrome looking nice.
Here's pipes I made on 360 and link to 360 build
http://www.dotheton.com/forum/index.php?topic=11736.0
