Removing C snap rings?
mysta2
Over 1,000 Posts
DTT BOTM WINNER
My VFR rear wheel eccentric has two bearings that are held in with snap rings that I don't know how to remove.
Item 26
I've got a couple pairs of snap ring pliers, but these rings dont have any holes in them to put the pliers into, the ends are just angled so that if I had something to get in there that was just the right width to catch both ends at once I might be able to get a screwdriver in between the rim and the ring and get it out... but there must be a better way because I've already started to damage the rim with screwdriver monkying. If I wanted to do this in a professional manner, what tool would I be looking for? Sharper snap ring pliers?
You need snap ring pliers not circlip pliers.
What you have now sounds like circlip pliers
Snapring pliers are flat on the end with a little divot to catch edge of snap ring.
Pretty sure any Harley dealer will have then as that type of snap ring was used on HD transmissions for years
Yes, that's probably true.
I've got this worthless junk set:
And this pair:
Which seems to be fairly good quality
I guess I'll have to look through the set of ends for the Channel Locks and see if I've already got what you describe.
Thanks
Klein tools do them as do Buffalo - available at Home Depot. Snap on etc probably offer good ones. I have heard of people modifying needle nose pliers to do the job.
Channellock's got three different sizes of the style that I've got. I think I'll just end up getting those. I was hoping for a better solution than pliers though. The rings in question are internal so the only thing that pliers can do is spread them out which is obviously the opposite of what I want to do. I realize I just need to get the tips in there behind the angled edges and twist and pry and tweak until it goes flying across the shop or straight into my eye, so that's what I'll do, since there's no magical special tool that I was hoping for. I'll get it one way or another, I'm half tempted to just take it to Honda and watch what they do, but they'll just pry at it and scar up the seal surface just like I would.
Get a pair of extra long needle nose pliers like these:
Then make grooves with a file or cutting wheel at each tip to catch the ends of the circlip. That's what I did to remove the clip from my master cylinder.
Edit: sorry, you need the opposite action.
Your snap rings have angled ends - yes. The angles are such that if you apply force to them, the angle will create an inward force which will cause the clip to move in and allow it to be removed.
