Removing Cam Chain???
hecklejk
Hey guys, I am in the process of rebuilding my 74 CB200 engine and have runinto an issue getting the motor apart. I am having trouble getting the CAM out.. I cant seem to figure out where the CAM Tensioner is, and I have to remove it to get the CAM chain off.. I have removed the 2 bolts on the CAM sprocket, so the CAM is free of the chain but I cant get the chain off of the sprocket. If anyone has rebuild a 200 motor or something similar, please HELP!!! I am getting a little annoyed with this motor!!
Cheers
Everyone is going to ask, so I might as well be the first - are you using a manual? Clymer, Haynes or the Honda Service Manual?
That being said, the sprocket should move off the cam, and you should be able to remove the chain from it, if it's like the CB500/550 and other Honda models.
The tensioner adjustment should be in the centre of the cylinder block on the 'back' of the engine (facing the back of the bike).
YES!!! I am using a shop manual, I got it from a post on this site(thank you!!!)
The sprocket is off of the cam, but the chain is still very tight and I cant seem to pry it off of the sprocket. I did not see an adjustment screw on the back of the motor, but there was an adjustment bolt of some sort on the front of the motor (will take photos this evening).
With the sprocket off of the cam, the sprocket drops down a bit from its normal position but the chain just will not budge off of the teeth!
Yep - its on the front of the engine on this one, between the exhaust ports.
This manual is here:
www.dotheton.com/downloads/Honda_CB200_CL200_Manual.pdf
Tim, thanks for the info!! I loosened that bolt, but still could not get the cam chain free of the sprocket.. Do I need to completely remove that bolt when disassembleing the motor?
No - but you have completely detached the sprocket from the cam correct? There are two bolts. The sprocket should have a large enough hole in the middle that it will then lower onto the cam shaft, allowing enough slack to remove the chain from the sprocket etc. (page 18/19 of the PDF file).
I have both of the cam sprocket bolts off of the cam shaft and have seperated the cam shaft from the sprocket, dropped it down a little but still cant seem to get the chain off! I may have put the tensioner bolt back in thinking that it was not the cam chain tensioner bolt.. will give it a wack this evening! Thanks for the help!!
Thanks for the information Tim, I was able to get the cam chain off but I ran into another issue which turn out to be the underlying problem with the motor! gonna start another post on that though! Just wanted to say thanks for the tip!
