Removing left engine cover and disconnecting alternator? It can't be this hard!
jh321
Active Member
The bike is a '69 cb350.
I have removed the left side engine cover and unscrewed the alternator from it but the alternator comes out the outside of the cover but the wire runs through the cover... So basically I have a case that I want to be able to walk off with but the alternator wire is stopping me. Am I over thinking this?
You must remove the left crankcase cover to remove stator, some oil will drip from the bottom. You may then need a new gasket if old gasket is torn.
I have done that. I can't remove the alternator from the crank case cover. Here's a picture:
That wire runs to a plug.
Unplug it.
Re: Removing left engine cover and disconnecting alternator? It can't be this hard!
Unplug it.
Hahaha i'm with stupid :P
95% of the times it's something you will smack yourself for when you discover how simple it really was.
