looks like corrosion has taken a hold...apply a penetrating oil and then the use of isolated heat on inner shaft(inner seal may be ruined if you get it too hot)...first install cam retention bolt almost all the way until you have about a 1/16 or so gap from bottomed,concentrate heat on aau inner shaft, then get two screw drivers(short leg of 90 degree mini pry bars work best) and put 180 degree apart and pry from the back lightly then tap the bolt sharply but lightly .if no help tap the outer shaft side to side lightly with a plastic or rawhide mallet and then try all previous again... biggest thing is to not get too agressive and damage anything.. if there are any internal threads on aau(not the inner shaft)install a bolt and use a slide hammer...
joe@ vcycle
