Removing swing arm bushings from CB
cr8zy1van
How???
I have tried pulling them, heating and then pulling them. Pulling them, heating the swing arm while cooling them but they wont budge. (In frustration I may also have tried beating on them with a mallet.... They feel solid as the day is long!) I would love to replace them with a bearing set I bought but it they do not want to move. I have a 72 CB500, is there any chance they are part of the swing arm and not replacable?
Check your parts fiche to see if they are bushings... but I had to mini-hacksaw/dremel mine out. Just cut a small section out to relieve the tension and they'll slide out.
If you do, just be sure to cut *really* carefully and not hit the swingarm. I didn't cut all the way through and then just broke the bushing.
I used a hacksaw and chisel to get mine out as well. Hacksaw to cut some weak points into them and chisel just to break them the rest of the way.
I have 76 cb360t. I just removed mine last week. I tried beating them w a hammer and long screwdriver for a minute...didnt budge. Then I used the propane torch and warmed the swingarm tube on the exposed side till the grease just started to smoke. Then with just a tap w hammer and screwdriver they pushed right out. I did damage the inside end of one just a bit, From the previous beating. But the plastic bushing will clean right up for re-use w Emory paper.
