Removing valve guide from honda head.
Kanticoy
Mad Science!
DTT BOTM WINNER
Any tips? I know the standard process of heating, but any tips on how hot, and any special tools that might make it easier? Any tips would be awesome! C'mon, I know y'all have it in you!!!!
they should be able to be pressed out, I'm sure there's a tool made specifically for it, but you could probably work up something
assuming it's a press fit, and the guide is a relatively hard material, they could be removed by hammering them out, as long as you had a way of keeping the hammer from hitting the guide off kilter
Yeah, if I knew what they were made of I would....It's just a little sketchy....I just found out they make an OEM guide driver. Need to know what size and where to get it!!!
At the shop I worked at we used to put the head in the oven, and drift them out while the head was still hot. Same process for installing them (except we would put the guides in the freezer as well as heat the head).
I already PM'd Kiley.
325~350 deg F, piloted drift for the rest of you :D
PJ
