Replace piston or not???
davidricci
Active Member
Hi Guys,
Please look at the photo. The PO of my '68 cb450 used a screw driver to try and unseize the engine. Put. Nice gouge in the top of the piston. Should I replace it or is there eneough meat there?
The damage in the photo doesn't look all that bad.
That said, I'm a firm believer in the concept of, "if in doubt, swap it out!"
It's been seized, so honing and possibly even a rebore are in your future, meaning fitment will be less than optimal. I've seen pistons replaced for a lot less than that!
Unless you are going to run the engine hard that gouge should not cause you any problems.
I would smooth over any high spots that could lead to a hot spot.
