To add to Worst 650 ever's post, that schematic is specifically for the late model 75 and 76 CB360 that have NO on/off light switch on the right pod, and no off position, only dimmer, on the left pod.
If your bike, when working, has a headlight off sweitch from the factory, then this schematic is not for you. I have a Factory Manual with all the schematics in it. The book has quite a few. US bikes are different then "Genreal Export" which is different from UK, different from French, different for Germany, a general european schematic too. there are different ones for different years, and disk versus drum front brakes have differences.
The bulk of the schematic is the same across the various models, but the differences reflect certain laws in each country at the time for how lights behaved, or the intensities of the lights....
US DOT implemented a vehicle rule that a motorcycle headlight must be on when the motor is running. The effective year was 1975. v The rule was for vehicles built in that year. since Honda builds bikes a year early, mst of the 1975 model year gikes were built in 74, so had a on/off switch. However, later production needed them and my 76 model, for example, was manufactured in 1975 so had to comply. I have no factory switch that allows me to turn off the headlight.
So my unit has a starter switch that turns off the headlight when depressed so as to allow more available current for the starter.
SO, pictures of the pods, wires, and switches help us help you. We can usually tell from a picture the actual model and schematic.
