Revving too high on freeway
A good combination is the 17/34 that nets you around 800 RPM drop if you are running close to stock sized tires. A 32 REAR sprocket with a 16 front will also get you the same results.
Official numbers! Honda cb360 17/34
I was wrong.
70 @5200, 80 @6000-6100
my chin, fingers and nuts are still numb as I type this.
anybody wants to call me a liar...is welcome to come and take her for a spin.
Well get back out there and don't come back till you have an RPM for 100 :D
LOL 85 is my personal maximum. actually thought twice bout doing 80 this time. But once had gotten up the guts to gas her over 75 it was balls to the wall. Yoohoo
The temp here is 41 F
wtf ? why would you do something that is uneeded ?
if you perform the test I outlined earlier this will verify if your clutch is slipping and or needs further attention
Finnigan said:
Haha thanks for checking trek
I'll consider new clutch plates and trying again
I shoulda checked 5th gear...Is there any possibility your not hitting 6th?
sorry hahahah that was another thread ;D anyway try to forcefully induce clutch slippage
If it slips it will be obvious when it does your rpm's will jump up
you should not be able to get your clutch to slip, it should hold in all conditions
so... go out on a short ride and once warmed up ,while accelerating ,in say 3rd or 4th gear,apply the brakes hard, enough to really drag down/drop rpms and while doing so give it even more throttle
if your clutch is slipping on the highway it will surely slip when trying to make it do so,but put some effort into it, really load the clutch
if you cannot induce clutch slippage with a few of these tests don't fix it,it ain't broke
Try and borrow an electronic rev counter and see if your tach is anywhere close to accurate (I removed mine because it was so far off)
What size rear tyre?
I would try revving it out and see just how fast it goes.
7K is fine, your running the 'right' oil, etc (if I remember right?)
Should show 95 pretty easy (unless your sitting upright, then it's faster in 5th gear)
110/90rear tyre on WM3 rim is good for at least 105 (with a 90/90 front on WM3 rim 'driving' speedometer)
With the over-rev capability of modified engine (plus clip-on's & rear sets) 115~120 is not out of the question with 378cc motor, 110+ with stock 356cc
I'm going to fit a 12v outlet and use modified Garmin GPS as it records max speed (plus, I'll be able to find my way home ;D )
I was thinking about a digital rev counter but was hoping to save it as a last resort. I have a gps mount and the MPH is pretty dead on past 40.
You'll can measure rear tyre circumference and see how it compares to 'theoretical' speed @7K
Easiest way to measure is line on sidewall and roll bike along for 5~10 rotations then measure distance (it works on a single rotation of wheel if you measure accurately)
Dug up the info on my tires from when I bought them, can i calculate just with these numbers?
Front is 100/90-18
Rear is 110/90-18
no
put the bike on the centerstand and wrap a tape measure tightly around the tire(a cloth tape from a sewing kit works nicely) and get it thataway or do as PJ suggested
it needs to be quite accurate if you are going to calculate an accurate number
even a new vs worn out tire is sig different
Been thinking about this...get out your manual and readjust the pressure thing on the sprocket cover. If the ball is putting a little too much pressure on the rod. This could cause it to slip (thinking the same amount all the time)
Even w the clutch lever adjusted to feel proper.
I am trying to come up w a way to bolt wife camera to my bike to vid the gauges. This weekend is first shotgun + shitty weather (of course) So, maybe I will have something to show come Thanksgiving weekend.
PS if she finds this out...she will go ballistic.
