gk45011
Coast to Coast
Went from the shop tuned 127.5 main-40 pilot- shimmed needle- 4.5 turns out: Changed to: 135 mains-45 pilot- shimmed needle- now around 3 turns out each.
Plugs look the same side to side. Picture below. engine temp is running around 245 degrees while moving if that matters. With having changed the jets up (Mikuni originals, not knock offs), The plug chop actually looks leaner than it used to.
Unless I am way off base counter clockwise would richen up the mixture. clockwise would lean the mixture out on the bs34 carbs (yes, I know CV's are the devil).
I received two sets of carbs with the bike. Neither one had all the factory jets still in them. I know that the later model bs34 for this bike came with 40 or 45 pilots. By going up to the 45 pilot I have almost gotten rid of the off idle stumble.
Can anyone tell me if I am on the right track. Should I try a bigger pilot since I am not sure which was the factory setting? I also thinking about continually stepping up the main. It pulled hard and solid all the way up to 95mph then traffic on the highway thickened up and I had to let back out of it. It is cruising nicely at 75-80 mph at around 6500 rpm.
Does this look way to lean to anyone?
