Rick's stator and electronic ignition- worth it?
runmikeyrun
Hey guys,
I'm pretty sure I'm gonna go with one of the Rick's Stators on my build, but I was wondering if any of the electronic ignitions are worth the extra scratch. I don't mind fiddling with points here and there, unless its a regular occurrence and/or a pain in the butt. I have to mess with my RD's points on occasion so the know-how is there. I'm just wondering if the stock setup will work good for a slightly modified somewhat-of-a-daily-rider. I've heard the horror stories about poor electronics so I'd rather spend a little extra $$ and have peace of mind.
Thanks in advance.
Although I've yet to test it fully, I purchased the PAMCO electronic ignition on the advice of many members here and on HondaTwins. I have the Gen 2 version not the current one with the E-Advancer. Not only does it eliminate the need to re-adjust points, it also produces a much fatter spark (something I can confirm) and therefore should likely produce a stronger ignition.
That being said, I don't see any reason why the stock setup wouldn't be fine. Replace the points/condenser, test your coils to make sure they are operating well, and get get some new plug boots installed on a fresh section of the plug wire and you should be good to go. These bikes lasted this long with just points and only really need occasional adjustment so if you'd rather not spend the $100+ I say throw your money somewhere with more noticeable improvement (like suspension).
