Ride Height
Hdaddy
Active Member
I have a CB750 K (1974 with a 75 motor); I am beginning its Cafe transformation from a true 70's snotrag of a chopper.
Sissybar - Gone
Apehangers - Gone
8" over forks - Gone, thank God the owner had a deathwish and did not alter the frame.
Snotty motor - In the corner for another project down the line
16" Rear wheel - Gon...uh...well... I actually like the 16" out back and I have a brand new Maxxis tire for it.
This brings me to my question, if I keep this on (after refinishing it) and mount my new 13 1/2 inch shocks should I switch to 2" under fork tubes to maintain rake/trail/handling? I have been told this but I have also heard stories of people loosing it in a corner because they are too low and a peg etc. grounds out.
1. How low is too low
2. do I lower or suck it up and mount an 18 incher out back?
keep the bike as close to stock geometry as possible
if you do modify things... think it through very carefully.
you can mount a smaller tire in the rear, and you can lower the front to compensate, and you're going to change the dynamics of the bike... sometimes this is okay, sometimes this is good and sometimes it is not.
I have lowered the front end on cb750's by about 1.5", shimmed the springs and went with heavier fork oil to compensate. the stock 750 is a little soft on the suspension side, so there is room to change things, but don't lower the front without thinking of the forces involved. The people you heard of eating shit around corners are those that f'ed with a bike without thinking first. Also keep in mind that a stiffer suspension will dive less, but can skip in cornering. Best method is to either get the bike to as stock as possible, or ask around to older motorheads who used to race the things in the 70's
Thanks for the reply, I think you have the same thought process as I do: Make her look good but dont sacrifice rideability and handling not to mention safety. Carpy was the one to tell me that if I use a shorter setup in the rear that I should go with shorter forks; I plan on installing a rearset next offseason so I want to ensure I don't go too low and loose it on a curve.
Does anyone know what the stock rear shock length is on a K4 or K5 750? Or what the difference is betwen a 16" rim/tire and the stocker 18?
shock length is 13.something... 3/4" maybe? off the top of my head... and as far as I know, the 16" rims were usually wider to accomodate a larger tire, giving something close to the original diameter at the road.
Anyone on here have a 16 on the back of a 750? Same for an 18? if I can figure O.D. on each if it is close I can keep stockfork length.
