Rim effect on rake and stability? RD350 vs TZ350
andrewlk
Requesting opinions to the following:
If I'm correct, rake on an RD350 is 27 degrees and a TZ350 has a rake of 25 degrees. Being very similar, is it desireable to make changes to achieve 25 degrees of rake on an RD? And, if so, is increasing the size of the rear rim a reasonable way to accomplish this without generating adverse effects?
Handling is the goal, but with the suspension and tire changes I already have made/plan to make handling will be significantly improved...is messing with bike geometry a waste of time?
Thanks, and if there's a thread on this I missed, feel freet to just send me there...
andrew
To begin with, the RD350 has excellent geometry, and if you want a really good handling bike, don't fuck with it. You are not going to make it better. As far as changing the rear tire diameter goes, that would have a very small effect on the rake.
There is a lot more to steering geometry than rake. Rake is determined by both steering stem angle, and rake in the trees. (Often, tree rake is zero.) The key is to achieve the right trail. Too much trail, and a bike wants to go straight in the curves, and low speed handling can be a bit on the heavy side. Too little trail, and a bike will be twitchy, with poor straight line stability or even tend to do tank slappers. Trail is determined by many factors including tree offset. Two bikes, one with 27 deg rake, and another with 25 deg rake, could have the same trail by virtue of the tree offset being different to compensate.
Here are a couple pages to read that should help you to understand how these factors affect one another.
http://www.rbracing-rsr.com/rakeandtrail.html
http://www.rbracing-rsr.com/advchoppercalc.html
AD supplied two very good links that are much the same I use to determine if I'm in the ball park with gross parts swapping and modifications . I recently swapped 17" rims on to an RD for better tire selection and other mods to regain ride height . Did have to modify the rake to get it to turn in a bit better but mention it here to provide an example of just how sensitive these bikes are to rake change . ONE degree was the difference between a stable turn in and a bike that required a little too much effort to roll in .
~kop
