rim widths for spoked wheels
bikeboy
Over 1,000 Posts
Hi gang. I was wondering what options I have for putting wider spoked rims on my cb400f? I'll need new rims and spokes at some point, so I thought I could lace my hubs to wider steel? Is this a good idea? Not quite used to working with old technology ;)
cheers
ian
Probably the biggest problem you are gonna have (aside from the loss of handling ability) is clearance around your suspension and drivetrain. My rear tire was originally 3.00-18 and the PO put a 3.25 knobby on there. Just that measly quarter inch was enough to bottom out the tire into the fender (I've replaced the shocks since then which helped) but the knobs were still able to rub the sides of the fender on just about every bump. Not a big deal - just replace the fender, right? But any taller of a tire could start making contact towards the front of the swingarm. Don't know if you have a front fender or not but there is always the clearance up there too.
I love the look of the larger tires on these older bikes but there are limitations to everything, ya know?
A Knobby is a bit extreme :o Seems you have more an issue with the aspect ratio rather than width? I'll bet there was more than a quarter increase inch in height?
I have done tyre/wheel swaps on my other bikes, and have an idea of some of the issues that may arise. Not sure why you suggest handling will suffer (unless I fit a knobby on one end ;) ) I have at least half an inch each side of the rear I could use safely and maintain clearances, and the front end is cbr-so there will be no issues there. I was more interested in finding out whether I can get a wider rim, and lace it to my 400 hubs? I'm not familiar with spoked wheels, so I'm gathering as much info as I can. I don't even know what 'standard' size rims are available? So far the only thing I know to look for is a 36 spoke fitment.
cheers
ian
you can fit WM3 rims front and rear although if your sticking with steel rims I would fit original WM2 rear onto front and just buy WM3 for rear. (I'm pretty sure front is WM1 stock)
PJ
PJ
thanks PJ, that's what I'm looking for. Are you able to dechiper the WM1/WM2/WM3 code for me? I've seen it before, but don't know how it relates to the size of the rim?
cheers
ian
You measure rim on inside where tyre fits.
WM1=1.60", 2.4" measured on the outside fits a 3.00/3,25 tyre
WM2=1.85", 2.8" measured on the outside fits a 3.25/3.50 tyre
WM3=2.15" don't have a steel WM3 to measure but it will probably be over 3" wide. and takes up to a4.50/ 120 tyre (people fit wider but its not a good thing)
They will be stamped somewhere with the size.
Usually you'll see rim diameter then width, i.e. 18"x1.60 or WM1x18 for a CB400f
PJ
bikeboy said:
thanks guys. time to start trolling around ebay ;)
cheers
ian
im not 100% on the rear wm4... lets wait till someone backs me up on it
WM4 is about $200 for rim plus you wont be able to fit 'correct' tyre without cutting and welding
CB400f is about same width swing arm as CB360.
Way oversize tyres on bike for 'styling' is only reason to fit WM4 rim, but if your going to that much trouble you may as well fit jackshaft , make swing arm and fit a 300 tyre ::)
(bike has enough power to turn tyre that size ;D)
PJ
