It's actually an "electrical" question. Without getting right into Faraday's law, your ignition coil is a step up transformer of sorts that operates on the current supplied to the primary coil being interrupted by the points and this sudden change in magnetic field in the primary coil causing a high voltage in the secondary coil which is applied to the spark plug. The interruption of current to the primary coil causes an inductive voltage that gets sent back through the points. This would cause an arc across the points. A condenser(capacitor) is wired between the points and coil to eliminate arcing. In conclusion, you need condensers, but I have always changed my condensers once for every 4 changes in points without any condenser failures.
