rookie question about carbs
bissinger
i just got an 80 cb750 and took apart the carbs to clean them as the bike idles when the choke is on but when you turn the choke off or hit the gas it just bogs down and cuts out completely after revving up a tiny bit.
after sitting there staring at the carbs i came to the conclusion that the slides on all 4 wont move when you twist the throttle, however you can move the slides with your finger. the butterfly valves open properly. i feel like it is something with the throttle but i can find what, as i think i've connected the throttle cable properly
does anyone have any input or any solutions? im baffled. thanks. i aprreciate any help.
Vaccum leak. If im not mistaken those carbs are constant velocity type ( dunno which model you have, but most bikes were using constant velocity carbs by 80 due to EPA regulations) Most CV type carbs have plastic diaphrams on the top of the slides (if you remove the covers off of the top of each, you will see what i am saying) You could have pinholes, or big tears in those diaphrams, in which case, they arent operating properly, as CV carbs rely on VACCUM to operate (which is why the slides dont move when you twist the throttle) , rather than mechanical accutation. Take the top covers off each carb and inspect them with a light bulb behind them. If you see even a tiny pinhole, they're shot. and whats worse, they arent cheap to replace with NOS parts either (bout 80USD EACH or MORE!! :( ) If this is the case, start watching ebay, or plan to pay out the nose for them. If they ARENT perforated at all, then you likely have an air leak somewhere else. Probably around the intake boots, or if you've removed the airbox for any reason and not rejetted, this will be a major cause. These carbs, because they rely on vaccum to operate, are EXTREMELY intollerant of air leaks. i have an XS400 that has the same issues right now, i just havent gotten around to tracking it down, as its on the backburner till the 750 cafe is done.
would a rip in one diaphram effect the vaccum in the other 3 though?
thanks for your reply, was very useful.
Not sure if a tear in one diaphram would effect the vaccum on the other three, but it would be enough to make your bike run like crap.
I didn't think the 1980's came with rubber diaphragms, what is the carb model on the left side of the carbs say?
