RPM's stay high
zuehl666
Active Member
Hey, I've got a CB500T with pod filters and open pipes. I'm having a problem with the rpms staying around 4k after i give it some throttle, it will stay around 4k for about 5-10 seconds and then come down to idle speed. Its idling fine and will rev fine all the way up to 10k but gets stuck around 4k. I've been having a problem with it running too rich despite the filters and pipes. After a good cleaning of the carbs its doing this. Is this a symptom of running too lean? I've tried fiddling with the mixture screw but doesnt seem to fix the problem. The main jets are the stock 145's .
A few things come to mind. Lube the cables and check routing, you need smooth bends not kinks. If you have a mechanical advance unit you might need to lube the mechanism. And deffinately check for air leaks at the carb boots and also check timing with a strobe timing light.
Terry
J'ville, Fl.
I checked the cables and for air leaks, everything seems ok. When I pulled the plugs out the tips were a white-ish color. I'll have to get a strobe to check the timing. I also just put new points, condensor, and coils on it. Heres where i'm at with it
Figured it out. When i put the new coils on i fed the clutch cable through the little cable holder that comes on the stock coils. I didnt have it fed through there before that, so it was too tight, pulling on the other cables and engaging the clutch weird.
