Yup, sounds like Ray nailed it.
The blinker you're using probably uses a single filament (1156) bulb. You can check this by pulling the bulb and looking at the bottom. If there's only one contact point it's a single filament bulb.
A single filament bulb only burns at one intensity. You need to have a dual filament bulb, which will burn at two different intensities. One for running light, and a brighter one for Brake light.
You'd need to change out the socket base to use the correct dual filament (1157) bulb. This is not difficult to do, and electronic parts stores should carry wired sockets. If you can't source one locally, www.superbrightleds.com has them.
