running wires
efocht
i need some help, drilled my the holes in my clubman bars to run wires through tied a nut to some string and fished it down. i then tied the other end to the wires of my control, but i can not get past the bend is there some kind of secret to this. please help i wanna ride my bike its beautiful here in pa
I ran a string through mine and tied that to a piece of wire (I used speaker wire). I pulled that through and then used the speaker wire to pull the big wire bundle through. The key is to make the leading end of the bundle as small/narrow as possible while maintaining a good connection to pull. Also, grease up the bundle so it slides through easier. Finally, push the wire bundle in until it stops and then pull until it stops. It is hard to work that much wire around the 90° bend. Small push-pull / push-pull motions should eventually work it through. It only took 5 tries and two martinis to get mine through. ;D
Sorry this is no help, but can you post a pic when you're done? I wanna see how this is done. I'd love to clean up my bike and hide some wires. I plan to hide all my electrical wire on the frame as well.
thanks iam gonna go try that now as far as martinis,i am a beer buy will a few pabst pounders work
I'm normally a beer guy too. In fact, I'm also a brewer. But at the time I did my bars, I was on a diet. No beer during the week. So I drank vodka instead.
PBR will give you the same feeling of invincibility required to pull those wires through. Go for it!
i owe you a pbr i pullled them first try took about 15 minutes but i got them done, my new left side control is in the mail that should go alot faster since there is only four wires :)
here you go....new signals are in the mail
thats great that you did it.
I had some problems myself. I pulled each wire one by one through.
congrats on your work.
looks really nice, flugtechnik.... so quick question regarding bolting the clubs on. where do you run the harness out of the bars?? thanks
Thanks, but I'm not really sure what your question is. Do you mean how did I figure out where to put the holes?
I first temporarily mounted the bars in the position I wanted and marked a line along the bottom of the bars in the area where I thought the holes were going to be. I then took the original bars and measured how far from the end the factory holes where and then transferred that to my bars. Where the lines crossed, that's where the holes went. The center one is easy because it just goes in the center. I ended up having my controls rotated a little from what I wanted originally so my levers would clear my turn signals so the outer holes were not exactly where they needed to be, but it worked.
I posted what I did in the $50 mod thread.
http://dotheton.com/index.php?topic=6496.15
sorry, what i meant by that was do you run the harness towards the headlight? out the hole then where?
Yes. Out of the hole in the center and then into the headlight bucket. My bike, '72 CL450, has the majority of the wire harness connections stuffed into the back of the headlight bucket (see the pic in the linked thread). Just run the wires wherever they were before.
