Rusty tank fix
nothingleft09
So I'm on my cell and I can't upload a pic right this second. But I will later today. So I thought I would take a shot at this metal rescue stuff. I bought 2 gallons and poured it into my super rusty tank about 9pm and came out at 10am and was amazed to find that nearly every spot I could see covered by the metal rescue worked. It was $50 for two gallons but that was a third of what i had seen some tanks going for used and cheaper tanks were in tge same condition as mine. So why not? I'm telling you guys. It was completely worth it and ill post a pic as soon as I can get it off my phone. Hope this helps some of you out.
Mike
Can't wait for pics - more solutions to rusty tanks we have documented, the better!
Ok so here is the pic I took. I can't really get better ones because the tank still has the Metal Rescue in it. Basically I put 2 gallons in a CB360 tank let it sit for 12 hours and the flipped it over. The pic you see is the line where the chemical is sitting. I took a couple pics and this is the best one then I flipped it over to get the other side of the tank. I was amazed. lol I'm letting my petcock sit in the solution as well. This stuff is water based and also it won't harm paint or seals or anything. As per their site it specifically targets iron oxide only. That being said it can probably mess up red paint without clear on it because all red paint contains iron oxide. So just be careful. Won't harm your skin or anything and IT WORKED. lol
From what I understand it neutralizes and removes the iron oxide from the metal leaving clean bare metal. It seems to work well also considering the state my tank was in when you look at half the pic.
It's probably phosphoric acid.
DO NOT soak your petcock in it! It's made of aluminum, and the phosphoric acid will dissolve it.
Phosphoric acid is pretty safe to use. It etched iron oxide quickly, but etches steel slowly. However, it DOES etch steel, so don't leave it in there indefinitely.
I recently had a rusty tank to deal with. I took it to a local radiator shop, and they did it for me for $45. I may never etch a tank myself again.
This stuff is awesome.
http://www.harborfreight.com/1-gallon-evapo-rust-rust-remover-96431.html
It says it contains no VOC's, Acids or solvents and is non-corrosive and is safe for all types of metals. But it doesn't give ingredients. It has MSDS on the bottle and is Zero across the board.
Yeah, I pulled up a couple versions of the MSDS, and could not get a clue WTF is in it. The MSDS says you can even drink the damn stuff. You can get it in your eyes and it won't irritate. Shit, I'm thinking I should get a few gallons to bathe in.
Lmao After being in a body shop I may consider that also. Hell I read some stuff on it that says if you filter it its reusable up to a year? I'm gonna do that and try it on my cousins tank too.
ive used metal rescue with great results. about twenty dollars a gallon and they sell it at home depot and menards. works like magic, all i did was pour it in and let it sit.
Now you guys post about this stuff. I've got a tank filled with vinegar. It appears to be working, slow but working. I've got 2 gallons phosphoric acid for my next tank. Maybe I should trade it for this stuff.
Vinegar definitely works too. I did that the last time I cleaned a tank. Just takes several days and several shakes.
