Salzburg '73 CB350 - Summer Riding Update
Re: Salzburg '73 CB350 - Update: fabricating custom stainless exhaust
Untitled by Matthias Salzburg, on Flickr
A bit more progress on the exhaust last night. Cut, sand, test fit, cut again, more sanding, fitting... seems to take a long time for just 24" of pipe.
Need some help on muffler positions. I can either mount it low and tucked up tight to the swingarm (at full droop) or I can mount it higher, but I might have less clearance when leaned over.
It almost seems like I have more clearance when mounted low.
Muffler mounting by Matthias Salzburg, on Flickr
High:
I can see issues with supporting it if I keep moving the muffler towards the back (higher angle & better clearance). I really don't like the idea of a super long strap from the top spring mount to help support the weight.
Thoughts?
Re: Salzburg '73 CB350 - Update: fabricate custom stainless exhaust - need opinions
High mount, more ground clearance and looks sportier IMO.
Cheers, 50gary
Don't forget that the peg bar crossed right there sir.
I'd go with the high mount and run your support to the footpeg bracket.
yup ide go with killerx too go high n secure to footpeg mount looks more aggresive too nice 8) coming on great style mate ;)
Exhaust by Matthias Salzburg, on Flickr
I checked again and it seems like I'm fine for clearance with it mounted high. I'd hit the foot peg at the same time as dragging the muffler. When I checked foot peg clearance many months ago the bike was damn near on the ground before the peg was dragging.
Also I can get the oil drain plug out just fine. Which is what I was aiming for.
How are you going to make your joint connectors, bolts, clamps,? Your merge collector looks good, properly done. Two into one systems sound great too.
Cheers, 50gary
I still cant get over how clean that engine looks... good work overall man cant wait to see the results!
Cheers, 50gary
I'll use springs on the collector and a hose clamp for the muffler. I still have to fab the hangers from the foot peg for the muffler.
Salzburg '73 CB350 - Update: fabricate custom 2-1 exhaust - polishing stainless
Exhaust welded and sanded by Matthias Salzburg, on Flickr
Right pipe is welded, ground flush, sanded (80, 120, 240, 320, 400, 600) and polished. The other two have only been sanded with 80. Muffler is mounted off the rear set bracket. Retainer springs will be added to the collector.
Re: Salzburg '73 CB350 - Update: fabricate custom 2-1 exhaust - polishing stainless
Stainless exhaust by Matthias Salzburg, on Flickr
Both headers and the collector have been final sanded and polished. The muffler still needs a bit of work. Plus a hose clamp to secure it to the collector.
I've got it back on the stand and will hopefully be doing wiring in the next week.
Sweet work mate looking cool 8) love to have that level of skill for my own pipework :P oneday maybe haha ::) great build keep up the good work mate ;)
Had some fun and weighed my stock exhaust with the new stainless version.
7lb 4oz
vs.
21lb 6oz
Over 14 lbs removed. 66% weight savings. 8)
Your attention to detail is incredible. Keep up the amazing work! :D
That turned out excellent. We need to get back on our 350. It's been sitting idel for about a month. Mainly due to laziness.
Re: Salzburg '73 CB350 - Update: exhaust finished - more wiring harness fabrication
Superb build.
Mind if I ask where you ordered your wiring sheathing? Exactly what I am looking for.
