Sam's CM400C Transformation
Here's a few pics I took of my friends comstars... Guess I forgot about the rest of the bike...
sorry about the 1.3 meg pics.. I only had my phone to use.
Thanks CP!
Those look as nice as I would have hoped! With them taken to pieces, the polishing will be a snap!
So it also looks like you're sticking with the 18/16 wheel combination.
Do you see any problems with going to a 19/18 set up for more tire options? Or maybe 18/18?
Also, the frame isn't straight under the seat. It dips down quite a bit. What do you plan to do around there and not have this big gap under your seat pan?
I am sticking with the stock wheels, and found some Avon tires that will work well - the tires will be oversized on purpose (ballooned out a bit)... I did consider going with different wheels, but I really dig the way they look, they are ugly, but the have character...
As for the dip, the back end will drop down slightly to mitigate some of that dip - and run more even with the dip rather than swooping back up as far...I have a pretty good eye for symmetry, as does the buddy of mine that will be helping to fabricate it, so I think it will end up looking pretty cool. The way the shocks will be positioned, it will end up bringing the rear end down an inch or two, which should give it a better look with the smaller rear tire too...
I'd like to see that. :D
Hurry up will you. ;)
I was thinking of going with an angled seat like a sport bike instead of a flat one.
Stay tuned, it's gonna be great!
On the sport bike style seat, I toyed with that idea too - like a streetfighter kinda. I didn't realize that you were asking earlier about the change of rims - I think you could go to an 18 easily - this thing has tons of clearance...you'd just want to go with the right size tire if you get any larger diameter than 18 on the rear.
I picked up the DOM yesterday. So we should be good to go on Sat. That bike will never look the same :). Weren't we going to drill and tap a rod for the shock mounts? Do we have that material? A 12mm bolt will likely need at least 7/8" rod...
--Chris
--Chris
I have none - do I need to get it...
I tried to post the pics of last weekend's progress, but I got the ubiquitous DTT SQL error and gave up. I emailed them to you.
--Chris
Apologies for the occassional error on the board - not sure why it happens, but I see it sometimes on other boards as well, including much larger ones that are hosted out the wazoo. I'm exploring new hosting options etc. but am not convinced moving from the $7 monthly I pay Go Daddy to $30 a month will help.
Happy Father's Day to those of us who are...
Chris and I started the rear frame mod last weekend, but ran into some minor design flaws with the shock mounts - those have been corrected, and it now only needs to be mocked up with a tire to make sure it will fit as planned, and I'll finish the welds and grind it all smooth.
Here she is just after we chopped the rear section off... you can see some of Chris' toys in the driveway...
Here's a shot of the stubbed slug that we put in to join the front and rear sections:
Turned out that the center bar where the threaded shock mounts are was about 1 inch too wide, so I centercut it and rewelded it prior to putting it back in place:
I realize these pictures are kind of "after" photos, but I was working in 100 degree heat, with gloves on, and picture taking was not at the forefront of my thought... Here's a picture with the rear grab bar, which is fashioned from an old set of highway bars off of Chris' original '69 CL350...
These aren't the best pics, but I couldn't get a good angle due to my car being in the way, and again it's too damn hot to be draggin' it out in the sun...I'll post up some better pics later... Also of note, some of my welds look a bit "boogery" but they're solid - I wanted additional material on the spot so that they can be ground smooth without taking away too much of the D.O.M. Next step will be to strategically tack in some gussets for strenght.
Also, I may adjust the grab bar down a bit, it looks like it will be just right with a 2" foam seat in place, as tall as it is now - it will also serve as a great handle for pulling the bike up on the center stand.
OH! one other thing...got my headlight, it's a standard bates style light (5 3/4') and I think it's gonna look pretty sweet on this bike...my original plastic bucket was cracked nearly in half, and the ears that held it in place were rusted pretty badly - this was a good 40 dollar alternative...
Back to polishing those rims... ;D gotta get that done before much else happens...thanks for looking!
That's looking good Sammy! You got a lot done this weekend. You pulled the father's day card didn't you? I'll swing by to check those welds. Worse case is that we grind them out and lay another bead.
That grab bar does need to come down a bit.
Did you use my welder or yours?
--Chris
5 to 6 hours - and yes, the Father's day card was pulled - though it was done on Saturday! ;)
Used my welder in Mig mode with a new gas setup, worked really well, though the aesthetics of my welds are not the same quality as yours of course - I have some practice to get there...
We'll look at the grab bar - bringing it down an inch or two will be easy as it is only tacked up for now...
--Chris
Hey Milenko, either that light is huge or your hands are really small ;D Just kidding, I like what what you're doing so far and I can't wait to see those wheels when they're done. I think it's going to be a great alternative to the black anodized look. Also, that chopper looks pretty cool too, I like the heat wrap on the pipes.
Next on tap, get the rubber mounted - trim off the old locking mechanism on the lower triple tree and weld on a mount for the bates-style headlight in it's place.
Once that is done, I can move on to mockup, and building the electrical box (which will look like an oil tank) in the place of the old air box.
