saving a 1980 KZ750 twin
doc_rot said:
The foundry I have access to is operated by the sculpture department at my college. As a grad student I get a pass to do pretty much anything I want; interlope into other programs and departments. Its awesome. That being said, this foundry pours metal maybe 6 times a year for the sculpture students so there is a VERY loose/crude process established here. Typically sculpture doesn't need to "work" so a lot of things that would make castings unacceptable for industry use are widely tolerated here. I blew their minds when I showed them how to do a "face coat" with chopped fiberglass in the investment. That should inform you to the caliber of work they are turning out. I asked for their advice on gating and started talking details and got blank stares in return; its something I know little about, them as well. I did one cover per investment to keep the investments physically smaller. I have only done the plaster/silica investment once before, the other times I had access to ceramic slurry investment which is much better IMHO. The castings moved around a bit and there is porosity throughout. Its not too noticeable unless you inspect close up. I would not expect them to hold oil but its for the ignition cover so its good enough.
The expense to run a foundry class has limited the ability to teach it and much of the knowledge has been lost as a result, save for what people can find online. For the most part, schools have shuttered programs, so to find a functioning foundry at a university at all is an achievement. In major cities or areas where there is access to commercial foundries, the process stops at wax positives in the studio and a professional foundry casts the work. I taught it for years, but we shuttered the metal foundry at Temple University in 2009 when we moved Tyler School of Art from Elkins Park to the main campus in N Philly. We didn't include a metal foundry in the Sculpture program in the new facility and instead, all casting shifted to the Glass and Ceramics programs where I taught. One exception is in Metals/CAD/CAM (Jewelry) programs, but that type of metal casting typically occurs in kilns or with torches. It's unfortunate.
Very cool. I have been contemplating doing some cast covers for the 360 using 3D printed masters. Definitely some good motivation here.
Did you use flux and degassing tablets?
You have about a 3 minute window to pour aluminum before hydrogen forms. Drossing flux and de-gassing tablets are pretty important when you don't have the equipment to de-gas.
http://www.ebay.com/itm/N406-Sodium-Free-Dross-Cover-Aluminum-Flux-1350-1470F-/250663652557?_trksid=p2141725.m3641.l6368
http://www.budgetcastingsupply.com/product-p/2011-010.htm
I was so mesmerized by the castings, I forgot to ask you what silicone rubber(s) you used and I gather, did a vacuum debulk on the rubber before you made the moulds?
Pat
very interesting
Pat
The rubber was leftover from another casting project, hence the two colors. I used Smooth-On's PMC line, I chucked the containers and don't remember which ones specifically. I did not use a vacuum.
I got the calipers mounts fitted. Should I do pocketing or holes? holes will be faster, but pocketing will be stronger. both will look cool.
Shoot Doc, that's a Brembo P08 if I'm not mistaken. One of the very few calipers that was around in 72 and still good enough to be used today. Or a Grimeca copy at least. I can't read the cast in name.
Good eye, indeed it is the P08, I like the old school flavor and you can get them brand new for $130. You may already know this, but it's a semi replica of the lockheed brakes that were common on 70s racers. In fact the lockheeds were standard on the venerable Kawasaki S1. A simular Lockheed design came stock on some triumphs as well but they were cast iron bodies and pistons. I actually have two of those OEM calipers and they weigh a 3 times as much. I have the Grimeca replicas on my kz1000, and the Brembos are definitely nicer
I have a P08 that I was going to use on a TZ350 project to replace the heavy cast iron stock RD caliper. The original Lockheeds are (or were last time I checked) available again. I don't recall if they are 3 rib or 4 rib. Good calipers for the time and still work well.
Good choice
Where did you find the new ones?
Good choice
That would be the perfect brake for that bike, very cool. do you have a build thread? I think the Lockheeds made by AP look cooler as they are pretty much replicas of the originals with the ribs and all, but they are significantly more expensive. Last I checked they were $250 each, but that was before the GBP tanked.
I got mine from Bevel Heaven, but any Brembo dealer can get them.
need some new bolts
First off - thanx to CC for pointing me in this direction!
Second ......... Nice work, good to see other Lonesome Twin owner's projects - I'm now a follower.
thanks guys. small update but the brakes are plumbed and cables shortened and routed.
