Sealed bearings for steering head
DrJ
Over 1,000 Posts
I have a hardtail frame and a springer fork that I want to install. I bought them separately so nothing matches up. The frame's steering tube is based on an old Triumph while the springer was probably for a Harley. The fork steering stem is 7/8" diameter solid rod and is threaded 18 tpi on top for the nut. So I bought a pair of 7/8" inner diameter sealed bearings and they slip right onto the steering stem, perfect fit. I did a quick mock up and it all looked good. Now I need to have bearing cups custom lathed to seat the bearings. Has anyone done a set up like this? Will the weight of the bike overload the bearings? I'd really like to hear of any experiences.
Why not just get the right set of tapered bearings? All Balls can sort it out likely no problem.
The engineers can chime in, but the sealed wheel bearings are not designed for the side-loading you're going to put on them. I'd be surprised if they lasted 5 minutes.
What's the ID of the steering tube and the depth of the bearing race seating areas top and bottom? Might be 55mm bottom by 15mm tall and 47 x 17 top.
Anyhow - get the measurements of the steering tube and stem and call All Balls. They actually answer the phone and will put the bearings you need together. They just mailed me a couple of seals for free that got damaged on my set as I had to remove the lower bearing and ruined the first one I did.
