Seat pan options
Cl 360 cafe build
This is the shape and look I want just can't decide on fiberglass or metal as pictured
Does it make any difference what it's made from? Once they're painted you can't tell the difference.
Find the style you like regardless of material.......unless you plan to polish it, either will work.
I don't know if you're any good at shaping foam and fiberglass work or not, but if you are, making your own out of foam and fiberglass is the cheaper, and lighter way to go.
Sent from my SM-G530T using Tapatalk
I originally wanted metal but I'm finding way cooler options open up with the fiber glass
Is there any particular brand or company that sells diy kits??
A DIY kit would simply be fiberglass cloth and resin. Lol. You would make your own shape. You can shave and shape foam and cardboard for your shape.
I'm in process of building a fiberglass seat at the moment. Not hard man, just messy and takes some patience. It's actually quite fun.
Yep any type of closed cell foam works good to carve a plug. You can make a skeletal form out of cardboard and fill it with expanding foam if you want to be precise, but I like to work it by eye. Tape it with packing tape, 3+ layers of glass,fill, seal, prime, paint.
Ok thanks everybody love all the input I will search the tubes for the materials
It's a cl360
I'm going the fiberglass route for several reasons
I think I'll be able to make a nicer one with cleaner lines
And have easier time than shaping metal to be the same
Florists foam comes in blocks, use spray adhesive to glue together however many you need. I used cardboard under the blocks, set them on the frame and start sculpting the shape you want.
I have one or two pics in my 750 Twin thread towards the end, i'm still working on it at the moment. I'll add more as I glass it.
index.php
Perhaps something like this?
Pat
onefromexile said:
Yours turned out great
I might go a lil smaller with mine I'm trying to match my tank lines
Really nice pics too
I have made a tail from cutting the back half of a tank off, in retrospect, I would have cut the tail and sides as one then simply made the pan to bring it all together. You can cut it again down the center to narrow or widen then just add a backer strip with holes and plug weld, then skip stitch the seam.
