Seat upholstery tutorial?
theprep
I searched through the boards/Youtube a few weeks back, did not see anything specific to my application, if so please point me there.
I have a new Airtech-Streamlining Bridgestone 175 seat for my Yamaha R5, I opted for the seat pan insert and would like to attempt to upholster this myself, quotes are around $300 and I have far too much in the bike to spend any more.
I did come across this business http://www.jacobsupholstery.com/motorcycle_upholstery that offers the material and Confor foam. My thoughts would be to buy some good adhesive, cut the foam to match the pan, layer to desired thickness, spary adhesive to adhere to pan, then get the micro suede cut to fit, work a section at a time, use adhesive to fit from one section, working my way to the edges and back?
I assume you spray adhesive to the back of the material to adhere it to the foam that would already be glued to the pan per the first step?
that seems high, it's built the same way I do the upholstery for my seats and I only charge about $150, if you wanted to, you could send it over to me and I could do it for you (pics of my upholstered seats are on my site for reference)
Oh it was going to be ribbed (minus piping, hate it) and red stitch, pretty similar to this.
I can see why the cost, I just have to reign myself in for now.
Agreed on the piping, looks/sounds promising though. And yeah I can't imagine paying $300 for a simple seat upholster job.
It was to be pretty detailed, so I can see the $300 tag, just can't afford that.
I sent the Bridgestone 175 seat back for the 350, was a hair too small.
I may give Roc a try. Found this which I like:
You have to figure that at 300$ someone can only spend about 2 hours on it at a reasonable shop rate, materials included. Nobody walks through the door of my shop for under 120$ an hour these days... Time is money, and if you don't have the skills yourself, and you haven't spent the years to develop them it's up to you to pay someone to do it.
Seems a totally reasonable charge to me.
I did some sewing back in highschool so I had a basic understanding of the skill. Just 2 weeks ago I was in the same situation;the bike was ready for a seat pad. I could either pay a local upholstery shop make one for me for $175-$200. I checked craigslist and picked up this 60's Phaff 332. All metal gears and heavy duty motor capable of using heavy duty upholstery thread and four layers of vinyl.
Pleating is simple. You layer your vinyl, 1/4" to 1/2" foam, and a backing fabric. I ended up using headliner becauase it was cheaper than muslin fabric:
Lay out some chalk lines:
Remember to back-stitch all stitches so it won't unravel on you down the road. After getting the pleats, sew the perimeter of the seatpad, leaving some room around the edges. I sewed a second line around to keep the edge flat.
For sewing on the edges, you use two pieces, one going around the back and one wraping around the front. You first sew it on inside out so the vinyl folds over, then sew it again on the outside to finish the fold. You'll end up with something like this:
I made one practice seat and a few scrap pieces to practice the tight curves to get it to look half decent. It sits on top of 1.5" thick dense foam and is very comfortable. If you have a steady hand and a good machine, the possibilities are endless. I got my Phaff for $150 and another $50 in materials. I can make about three seats from the material I got. I change seats and ideas so often I would have four or five seats and are useless to me. Now after I get an idea its only a good afternoon and $15 in materials. I'm definitely not an expert but I'm dabbling into the different skills needed to complete a bike myself. Thanks, Joe
Very informative Joe, exactly what I was after.
Thanks for the highly detailed reply!
Sent from my Radar 4G using Board Express
Now thats a skill joe :) that looks real cool 8) and maybe one way to fund ya projects :o i got the leatheret / foam and press stud kit if i find a machine ile give it a go thanks for the tutorial mate ;)
