VonYinzer
Over 10,000 Posts
Been chatting with some folks in regards to a possibly (read: probobly) rediculous thought. Were all aware that high operating temps are the bain of power generation and efficiency in internal combustion engines. So, the response is to find a way to lower internal combustion chamber temps during combustion while still allowing for proper air/fuel mix, lubrication and detonation.
People have gone about this in numerous ways, which I'm sure don't need mentioned here. One of them though is intriguing to me based on the relative simplicity. Nitrous oxide. The problem you have with nitrous in a small displacement, and relatively high compression engine like a motorcycle (and especially a two stroke in this instance) is that it creates such a volatile intake charge that it generally ends with engine parts crossing the finish line before the rest of the bike.
That said, nitrois oxide when added to air mix is still a very effective way of quickly reducing temperatures. So, my thought is that if anslow "bleed" of nitrous was added to the intake air BEFORE the fuel it would reduce intake temps, allow the air fuel mix to remain constant, and still allow the oiling system to work correctly by not cooling the incoming lubricant and changing its properties.
I've read in the past about intake "misting" or "bleeding" using number of gasses or nitrous being implimented by automotive racers in the past. The benefit of this type of system being that you get the cooling properties of the gasses without the volatile combustion and unruly high compression numbers. I'm still searching to find any info on these setups.
Basically I'm attempting to design and setup an intake cooling system that WON'T dramaticaly increase compressikn or create volatile mixtures opon combustion, that is seperate entirely from the oiling system on a Yamaha R5 motor. The motor WILL have been ported and "built" on the low end of full track specs so it can still be used on the street.
So, now that I've made nearly no sense... Let me have it. Ideas, experiences, thoughts? Again, keep in mind that I'm working with a "built" two stroke twin. Dual carbs. Mild expansion chambers. Mild track porting.
I've already spoken with one guy who is very well versed on two sroke engines having built and rafed them for yeara, and once ran a similar system on a carburated automotive engine so I know its possible. Whether or not its feasable is the real question...
Thanks in advance for any insight.
Mike
Mike
