Set of (4) K&N 2" ID Pod Filters
1sttimer
Over 1,000 Posts
Got these in a bucket of parts in a trade. Brand new. Only blemish is the ID of one filter. Looks like someone test fit it and didn't use them. Sell for $100 as a set. Yours for $60 shipped.
Here's the website for specs:
http://www.knfilters.com/mobile/mProduct.aspx?prod=RU-1824
Those and a set of these: would be worth a test on the KZ1K... Hmmm.
Those rubber? Might have to use a stainless coupler or something?
Lemme know man. I'm out of town starting wed-Friday so I could get them out tomorrow.
Yeah, the velocity stacks from the air box. I would rubber cement them together on a chunk of PVC with a clamp loosely fit, then trim and excess glue off and install with the provided clamps, should be real close to the 50mm OD on the stacks.
Will do need to check the stacks.
Re: Set of (4) K&N 2" ID Pod Filters
10-4 just lemme know.
I may be interested Let me double check the flange on my carbs. They're very close to 2" but not sure exactly how close.
Later, Doug
Later, Doug
Cool. If your application is small, these can probably cinch down 1/8" or maybe a little more to fit. Stretching to make them bigger probably not so much.
Well, my carbs measure 2.165" or 55mm. Looks like the filters won't work. Good luck with your sale.
Later, Doug
