Fear My Twin
Chicks hate my bike.
Can I request a quick vid on the basics of setting the timing and valve clearnace? Between the Clymer and the vid Im sure anyone could do these basic up-keep procedures.
HerrDeacon said:I wish adjusting the valves on the KZ was that simple![]()
Yes, I know its an easy job on the KZ, I was just referring to the fact that you could adjust those particular valves just by turning the screw and be done in five minutes, compared to having to remove the tank, valve cover just to check them on the KZ, and then buy different shims and remove the shafts if adjustments are necessary. Considerable more effort on the KZ. Plus if you ruin the valve cover gasket you need to buy another one of those as well. The process is really simple, but its considerably more work compared to the twins.crazypj said:KZ is real easy, you can see which lobes are up and down.
Pulling off chain tensioner and removing cams isn't a big deal, usually only happens every 2~3 years unless your doing high milage.
PJ
Fear My Twin said:This guy has several very good vids just walking through basic mechanical Honda specific parts.
http://www.youtube.com/user/IanJSeattle
quach said:Keep in mind that this guy adjusted his timing to the wrong hatch mark on the stator. You will actually want to align to the "F" mark. And off the top of my head, I believe on the larger honda twins (CB350/360 for example) you align the left points to the "FT" and the right side to "F"
Kanticoy said:Left valves to LT, and R valves to T on a Honda twin. An angled feeler gauge makes life MUCH easier unless you just adjust them by feel. Lik this:
