This GT750 Suzuki is getting to be a PIA. After fixing all the leaks from new components, I have it running really nicely except below 2000 rpms. At idle it shakes much like an old British twin except that it's a side to side shake and the front shakes not the back.
It has new pistons in fresh bores, new crank and seals, the same 145psi compression across all three cylinders. The plugs and wires and caps are all new. Carbs have been rebuilt and then stripped twice to see if I missed something. Ignition is a new Accent electronic from Germany. Carbs are synched and are spot on.
All I can think that I have not checked is the exhaust. The motor is rubber mounted and so (in theory) is the exhaust. I am starting to wonder if it's mounted too rigidly at the rear end and that acts like a pivot around which the motor vibrates and it magnifies it at the front end. Time to pull the rear exhaust mounts off and fire it up with a flexible temporary mount and see if that smooths it out.
