Shaving Heads on a Honda CX500
AlphaDogChoppers said:
Don't make that assumption. Rent a cylinder leak-down tester and determine where you are losing compression. Dollars to doughnuts it's your valves.
The thing about lapping valves is that there is a limit to how wide the valve to seat contact area is. (The service manual is quite specific on those limits.) If you lap them too much, your valve job will not last. You should only lap just enough to get them to seal. Too many guys lap the valves WAAAY too much.
After doing a little research, I realized that the CX500 already has a pretty high compression ratio, and one should not attempt to raise the compression. The real key to performance on this engine is Murray's carbs. (CXMAN) They are easy to install and adds 20% to the horsepower. The one I did dynoed at 59 hp at the rear wheel. It would easily lift the front wheel in the air in second gear, even if you didn't intend to. Power starts coming on at around 2,500 RPM and pulls like a freight train right on past redline. With the stock carbs, it didn't start making good power until 5,500 RPM.
That's pretty impressive for basically a stock CX 500. Bike was always designed to be a revver not a plodder. Keeping it over 5,000rpm make cam chain tensioners last more than 17,000 miles 8)
Could re-work the hell out of one for the 500 pushrod class at Bonneville
as long as cranking compression doesn't go over 225psi it will run on 95 octane pump gas ;)
21 30 35 45 60 thou copper head gaskets got em
stainless steel larger diameter valves got em
550 big bore kit got that to !
problem is its way cheaper to just swap in a 650 than boost up the 500 more than carbs and exhaust it just costs to much today for parts
best news is if you have my carb kit for the 500 fro 20 bucks you can re jet it for a 650 same intakes in a 500 frame
Makes sense.
I'm in the process of moving into a larger shop. Good traffic exposure and in an excellent area only 22 minutes from home.
Is the Glenside address the new spot?
I wouldn't mind setting up one of these bikes as a vintage racer
That would interesting as 592cc 550's are making 70+HP and pulling about 11,500 on a long straight (not even Mosport) in Canada. Go for it.
Rich Ard said:
Looks like you have about eighty places to plug a mill in ;)
The place is wired within an inch of it's life. It has 200 A, 3-phase service, and 3-phase outlets every few feet along the wall and hanging from the ceiling.
No, the new address is in Horsham. I guess I need to change my profile info.
Just found out today that the beer distributor around the corner is closing the end of June. DAMN!
You're not talking about Madonna's are you? Please say it isn't so.
I got that part. Good luck in Horsham, brother. I hope it brings you what you're looking for. Good living up there.
