Shell Rotella 15w40 Oil
Vince Lupo
Ridden Not Trailered!
Anyone here using Shell Rotella in their bikes? I've heard many things 'yea' and 'nay' regarding this oil, and I've been using it in my '66 305 SuperHawk now for a few years. It does meet JASO MA standards, but I've had a few people questioning the wisdom of using that oil in a high-revving motorcycle.
Thoughts?
JASO MA spec means it's OK for wet clutch.
Higher levels of ZDDP means it's good for cams and rockers (and transmission gears ;))
Will probably still need changing at 1,000~1500 miles though.
PJ
I use it, works really well.
The people who say its not meant for a "high revving" application forget that diesels have turbos that spin faster and get way hotter than our bikes ever will.
Thanks for the input, and I have a bit of information to share too:
I decided to go to the proverbial horse's mouth this morning and called the Shell techs directly (800-237-8645). I explained to them what I had, what I've heard, what I've read, and the varying opinions. They told me that about 1/2 the people in their office ride motorcycles, and they oil they all use is.......Rotella. 15w40 in the white bottle.
True, it is not advertised as a motorcycle oil, but it has all the properties that motorcyclists look for in an oil, particular the absence of friction modifiers. It's only recently that they've added the JASO MA designation to the bottles, as the Shell people bugged 'the powers that be' to add it to the bottle.
I mentioned that the Honda SuperHawk owner's manual advised the use of 30w non-detergent (this was 1966, after all). The Shell person recommended that if I'm switching from 30w to the Rotella, to let the Rotella sit in there for a couple of days, then drain and refill (due to the crud that it will probably attract).
So, it all sounds good!
