Shifting issues?
pawn
Over 1,000 Posts
So I finally...finally got my bike on the road last night for a test ride. Did about twenty minutes. Unfortunately with my new bars, I have to get a much shorter throttle cable (about 10 inches shorter minimum, the throttle is sticking a bit.) Not a big problem at all.
The problem I see/feel is the shifting. I was going from 2nd to 3rd and didn't use the clutch (I rarely do after first gear). Generally a bike would engage just fine, but my bike took a second to bite the gear. Then later when I came to a stop in front of my house I turned the bike off, but then decided to ride down the street to show my brother the bike when I couldn't get into neutral. After letting the bike sit for about ten minutes to cool down (my head as well) I finally got it into neutral. Now what is this a sign of. I imagine the springs are fairly old and due to lack of use they are slow to grab. I did roll the bike back a bit to let it engage and there was no click, but it did work. You think this is a sign of problems or just regular old school technology working how it's supposed to?
once upon a time i had a shitload of clutch drag on my race bike and it turned out to be a worn clutch basket. the notches that the plates had worn on the fingers of the basket prevented the plates from getting very far apart and the viscosity of the oil was enough to put some real pressure on the transmission. my latest stupid bike purchase is my CB3fiddy and it shifts ok when i'm under way, but i just can't get neutral when the engine's running, and 1st to 2nd is tough... so i'm wondering if a worn clutch basket is what this problem is!
