shifting problem
Bill005
I took my XS500 for the first ride today and it would not down shift past 4th. It up shifted through the gears fine, then when I down shifted it went from 5th to 4th fine but would not go any further. It did not make any noise just won't move. It will still up shift and down shift between 4th and 5th fine. Any suggestions would be greatly appreciated. I hope I do not have to split the cases >:(
Thanks
I "played" with the shifter some more and got it to shift through the gears again but still don't know why it did that. There is a small amount push/pull play in the shaft. Is that normal?
