sleazy
"everyone has a plan…"
need some help from some of you electrical geniuses out there…
ok, here is my build thread if you want some background:
http://www.dotheton.com/forum/index.php?topic=59573.0
but the short of it is- building a '71 CL450 from the ground up. engine is done, carbies are done, and just got the electrical harness from Sparck.
got it running the other night. and was quite happy about that. (running bike means valve timing, spark timing, carburetion, compression, etc are all at least close enough to run). so started cleaning up the harness, tightening stuff up and getting the lighting hooked up.
now, first weekend since running- i'm trying to get things really finished up and I've run into a problem. -there is a little shock i get on my hand that seems to be in keeping with the spark plug.
now- its a keyed switch -like an automobile- you throw the key to engage the starter motor and then relax it once she's lit. -its not a plastic handlebar push button.
when i turn the key and my palm is grounded -you can feel it.
now the worst part is- she's now got a nasty, small but sharp back-fire. and now she won't run. (starter will crank- but she won't get going.)
I've checked the harness over and everything seems to be connected as designed. can someone out there help me out with a few scenarios that would lead to this sort of problem so i can at least have a starting place to look?
many many thanks in advance.
(one tiny detail to add-- the stator wiring was really faded. four wires. one had a red stripe that looked like it came out of the neutral switch. the other three were really faded. one white-ish, one yellow-ish, and one green/grey-ish. the harness has a brown (neutral, so that's easy), a white, a yellow, and a pink. so i hooked the green to the pink. sounds logical- but is there a way to test if stator/rotor is hooked up right and is charging as it should? thanks)
