Shop for CB360 Jets
IanOberholtzer
green behind the ears
cant seem to find any sellers for the jets i need, everyone sells the primary jets but not the larger secondaries i need, anyone have a source? or the part number from Keihin for that matter?
Over on Hondatwins, members Greenbush and Dirtbag dealt with this exact problem. Apparently Honda used a lot of proprietary jets that noone has anymore. When you say you're looking for the larger, you're talking about the 110 secondary? Are you looking for non-stock sizes, or just to replace your jets? I've got some 120s, 125s, and 130s, as well as my stock 110s, but I'm not sure what setup I'm going to end up using until everything is back together and I start tuning. I got mine from Dirtbag, but I might be able to find out where he got them.
For the record, I've been unable to find any of the Primary Main jets (my 360 has size 68 primary mains). They're rather odd. The threading is larger in diameter than the head itself. I can't find them in any size, and will likely end up drilling mine out if needed.
Unless anyone can chime in......
I've checked all the usual suspects, like Jets R Us and what not.
I had the same issues so I made some.
The pilot jet is under blanking plug, I've never needed to change it.
Usually only the secondary mainjet and air correctors need changing
Secondary is a standard size thread for Kei-Hin round jets (different to Mikuni)
You shouldn't need anything bigger than 115, usually 110 is plenty.
Needle is non-adjustable, don't shim it or it will be way too rich mid range (it's going to be rich anyway with bigger mainjet)
PJ,
I haven't read much of anything about the air corrector changes you mentioned...If you don't mind, what needs to be done on those? I plan on running pods and 2 - 2 exhaust with mufflers and am obviously winging it.
Would that have anything to do with the "cough" I keep hearing about with that type of setup? I've seen a lot of people mention a cough when they're cruising at 3 - 4k RPMs.
Different type of carb.
I have that link, they have mainjets but don't have the airjets you need ( no-one has them)
i got my primary/seccondary terminology mixed up,
long story short, im looking for a 118 + 70 setup, found the 118 here
http://www.jetsrus.com/a_jet_kit_street/honda_360_CB360G_1974.htm
thinking i should just pull the trigger on that, and see how it runs with the stock 68
What have you done to think you need a 118 mainjet
stock 68 will be lean if you've done any airbox or exhaust 'modification' (68 is primary main, you need to change the secondary, 102)
ok, so here is my run down
76 cj360
at sea level
stock setup from honda is
CJ360T
*Main Jet
Primary 68
Secondary 110
*Slow Jet 35
*Needle Setting 2nd notch
*Pilot Screw 2 complete turns open
*Float Level 18.5mm (0.730")
no muffler after the collector on my 2-1 exhaust, has a about 8 inches of pipe after the collector that ive added on, ( no baffle, for now)
Pod Filters
so, according to the theory suggested in this article http://www.motorcyclecarbs.com/Jetting_Rules_of_Thumb_W43C551.cfm
i need to step up three sizes from 110 to 118
and one size up from 68 to 70
and hopefully i should be able to get a good running bike with the proper adjustments and lots of luck ;)
north city looks promising, thx!
Mine runs awesome.
68 pilot
115 main.
Pods, open exhaust.
Needle not shimmed at all.
Everything else stock.
with open pipe on CJ you can use a 120 main without any problems.
It will be rich midrange but if you have adjustable needles you can drop a notch to lean it off a bit.
There is no information on air correctors because I'm probably the only person who has done enough work on CB/CJ motorsto understand what they need
I'm still playing with mine, running 112 main, 68 primary, ordered 66 and 64 though, as running under low load cruising with partial throttle opening the bike stutters and chugs until you open the throttle a bit, lowered float height 1mm too
