Shorten cables?
porkchopper
Hey guys is there anyway I can shorten my stock cables on my 450 so that they will function correctly wil clip-ons? The OEM length with clip ons just doesn't look or function good.
yes there is a way to shorten them, and it works just fine...no need to replace your lines if they are in good condition. There are connection pieces available that basically are what's already on your cables. You cut your cable to size, thread the weighted ends, fray the cable at the end, and drop a pool of solder in there...then just clean it up and put it back together.
Yup! Just be sure your cable is really clean and de-greased and use silver solder (plumbing type works just fine for this). Heat the end piece and the cable, use flux and go to it!
