Shorter cables...
Deviant1
Over 1,000 Posts
The last time I looked into getting shorter cables for my throttle and clutch (many moons ago) the consensus seemed to be with cutting them down myself. Now I'm not opposed to figuring all of that out but I was wondering if anyone knows of a different way. It seems like you can buy everything you need nowadays so... Any suggestions?
Pretty sure you can contact MotionPro and they will make custom length cables for you. I trim my own but a lot of people seem to go with them.
I've used Venhill for custom cables, ferrules etc...
https://www.venhillusa.com/
It was a couple of years ago that I used them, but at that time they were very helpful, shipped on time and had reasonable prices.
Good luck!
Just spent some time bouncing around on YouTube and found several different tutorials on shortening cables. Looks simple enough, so I'm going to give that a go.
To solder cables back together, I use 50/50 lead solder in a solder pot with rubyfluid past flux. Most importantly make sure the cable is clean (I use acetone) and you have properly splayed the end of the cable.
You just want to get the solder/cable hot enough to break the melting point of the solder. I set the pot just warm enough so the stuff melts. Flux the cable end and inside of the ferrule, and heat up the cable and ferrule slowly until the flux bubbles off. With the pot, I dip the end of the cable/ferrule right into the solder (it's only about 1/4" deep, too deep and it will wick too far up the cable and create a stiff spot). A good solder should be shiny and have no bubbles or black sooty looking residue.
Propane torch just like soldering copper pipe. Heat where you're soldering and put the solder in the flame and watch it flow into the hole.
