This spring I have had to put the charger on to 10amp engine boost to get my 79 KZ650 to fire up. It spins over reasonably with the battery but it still needs that extra kick - Starts good after running a while.
Normally this would make me think the battery is due to be replaced. But I thought I'd check a few things before I get one.
Turns out both sides have the ignition retarded. Fires about half way between the F & T mark when I check static timing with a light bulb & alligator clip set-up.
I'm thinking that it could start better with less retard. Anyone care to chime in??
