Signal light problem
tone74
Hey guys, almost done with my bike for now. got an issue with some led signal lights I installed. the bike is a cb175. When I removed the front factory signals they only had one wire. I'm guessing the signal light housing making contact with the headlight ears and so on made up for the ground wire.
The problem now is that I wired the leds to the correct wire for the signals. The negative wire I connected to the head light bucket. When I turn one of the signals on they both light up. Not sure if it has anything to do with it but I replaced the headlight ears with some aftermarket ones that have a rubber boot around the fork tube so the only metal for the ground that I can see is the ears and headlight bucket.
Can this be the reason they are both lighting at the same time. Also I have yet to install a led flasher relay to get them to flash correctly, can that have something to do with it too? Thanks in advance...
You can jump the grounds from the signals to the green wires inside the bucket - but im sure you have that figured already.
Your turn signal relay needs to be replaced as well. The stock one doesnt recognize the draw from the leds. Go to your local auto parts store and look for one that works with a low-current draw.
Yeah Rich, the green wires are attached to the screws on the bucket so I connected the ground under the screws which is the same thing but I get both signals on when I move the switch left or right. The rear signals seem ok its only the front.
I should get the relay on the mail today.
Anyone got any other ideas? I guess I can run a ground directly from the frame and see what happens...
Sounds like they are not grounded, so when you turn one on, the only way for it to work is via the other and then back to the rears.
Try a good ground lead to the frame.
Oh, you mean the left and right are coming on at the same time? Pull the indicator bulb out from the speedometer. Pretty good chance that's where it's crossing signals.
