Signals and Tail Light don't Flash
thekeezler
Hey there,
Wondering if I can get some advice on this. I've got an 82 GS 650.
I recently purchased these cheap cat-eye signals: http://www.motorcycle-superstore.com/2/10/212/27024/DPITEM/Dirt-Bike-Motocross-Turn-Signals-Western-Power-Sports-Cat-Eye-Turn-Signal.aspx
And this LED taillight: http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-lighting-parts-chrome-cats-eye-taillight-49-2906.html
The taillight is LED but the signals are not. Wired em up, when I activate the signal it goes on but does not flash. The tail light also goes on but does not activate the brake light when I hit the brakes.
Any tips or suggestions on where I should start, do I need to do any changes to my electrical? I know this is kind of limited information, so i'm not expecting a full answer but maybe some tips on where to start.
Cheers, and thanks.
First off, everything worked properly before you swapped over to these?
If not, we need to start elsewhere.
If so, let's start with the signals. They look to be a "one wire" design, which means they ground through the mounting stud. Are they mounted to metal (directly or indirectly to the frame) and not through rubber isolators of any kind? If they're not grounded properly, they won't flash (usually they won't come on at all, but I've seen small ungrounded lights work). You can check for proper ground by running a jumper wire from the signals mounting stud to a bare metal spot on the frame, or better yet, to the negative side of the battery.
As for the taillight, it's probably just wired wrong. Did it come with a wiring diagram telling you which wire was for ground/brake light/running light?
Got the signals working properly. Still have an issue with the taillight though.
It activates the brake light only when I pull the brake lever hard, so it doesn't give any indication when I am braking to slow down. It does nothing when I use rear brakes. Any idea? It's quite dangerous.
