Simple Rookie Bodywork Question
Jojah17
Active Member
Hey guys, I'm filling the badge holes left on my CL175 tank before I spray it. I've followed the outline in this thread: http://www.dotheton.com/forum/index.php?topic=22243.msg234257#msg234257.
My question is this....do I fill the gaps up to the point that they meet the rest of the tank and stop or do I overlap a little bit and feather the edges? IE: if i was looking at a totally naked tank with body fill would it look like body fill in the shape of the original emblem or a larger square/circle where the emblem was. Also, I think I understand it but whats the best method for feathering? Thanks in advance.
You need to spread it out a good ways past the emblem
Area so that you can keep the shape of the tank, otherwise Youll be able to see the are is uneven under the paint.
Make sure you do it on bare metal, use a heavy amount if filler at the area you are covering then lightly thin it out while keeping the shape of the tank.
Let dry and work with some 80 grit sand paper, then some 120 and so on until smooth, and until the shape of the tank is created. Remember to be patient and work slowly.
+1..........what he said. Also it is a good idea to use a glass strand enhanced filler for the first coat, like tiger hair, kitty hair, etc. it has various names but contains strands of fiberglass. I always use this for a first coat, prevents moisture damage and holds up to expansion/contraction.
As a general rule do not apply filler to bare metal. Seal your metal first with an Epoxy primer and apply your filler over top of it. Do not apply any filler thicker than 1/8" at a coat and in fact try to limit your total thickness to one eighth of an inch. To do that remove dents and grind down welding beads first.
In the case of covering up emblem mounts you need to first roughen up the metal of the mounts themselves as well as the surrounding area, by an inch or two. Now get a flexible straight edge and hold it to match the side of the tank and pull it back looking for a gap between the metal and the edge that indicates high points. Its likely the mounting strip is high. If it is take a small ball-peen hammer and tap it down, Don't start filling anything until you get the highs knocked down. Once you've got the tops knocked down then seal it with our epoxy. Apply your filler with a squeegee pressing hard for the first coat. You should have got it flat enough that a second coat, less than 1/8" thick, will suffice to over-build your countour. Now begin your sanding. Get it to shape ending up with 220 grit, then reseal it, shoot your high build, and block it.
Alright so bondoed (Dynalited) and sanded. Bonded and sanded. I keep ending up with little pock marks/streaks in the body filler. Where am I going wrong here? Should I press down harder when I apply the filler? Filler lighter? Heavier? Sand more? Less? I'm lost!
